740 no start
Old Aug 31, 2019 | 11:39 AM
  #41
act1292's Avatar
Originally Posted by Syndave
Okay so fuel pump is in and it will start and run but it only runs for a minute or so then cuts out. Fuel pressure is good. Any ideas? It has a code for low/high battery voltage and idle control valve or something like that. It will just turn off like someone turned the key off.
How is your battery? Check the voltage. A low battery can cause weird problems on some cars. A quick check with the voltmeter can verify. Check it with the engine off, engine on at idle and at higher revolutions. Should be above 12v with engine off. Should be somewhere around 12-14 with the engine running. Shouldn't go much over 14v when the engine is revved.
Old Aug 31, 2019 | 01:18 PM
  #42
Syndave's Avatar
Battery is good. Fairly new too
Old Sep 1, 2019 | 06:52 AM
  #43
act1292's Avatar
Did you check the voltage?
Old Sep 1, 2019 | 07:05 PM
  #44
Syndave's Avatar
I did. It seemed fairly normal. Went between 12.5-13.4
Old Sep 1, 2019 | 07:29 PM
  #45
that was 12.5 when the engine had been off for awhile? thats a mostly charged battery. and 13.4 when running? that means the alternator is working .... if it went BELOW 13.4 while running, then the alternator is having issues.
Old Sep 1, 2019 | 07:30 PM
  #46
Syndave's Avatar
Yeah 12.5 after hasnt been running and 13.4 while running. It sometimes wont start but then after a few minutes starts right up and runs for a minute before cutting out
Old Sep 5, 2019 | 08:13 AM
  #47
Syndave's Avatar
Update. Issue is fixed.
Old Sep 5, 2019 | 01:43 PM
  #48
what fixed it ?
Old Sep 5, 2019 | 06:27 PM
  #49
Syndave's Avatar
Originally Posted by pierce
what fixed it ?
Wiring to fuel pump relay was messed and not connecting properly
Old Sep 6, 2019 | 01:09 AM
  #50
huh. with the integrated fuel/relay panel on the 740/940 being in such a protected location behind the ashtray and on top of the transmission hump, I have trouble seeing how that wiring could get messed up. I did have one relay socket on one of my 7/9's loosen up such that it made a flaky connection, this was because someone had stuffed a extra wire into it for a cheesy stereo install. I had to pull the relay panel, extract that pin socket from under it, and carefully pinch it back together so it would get a firm grip on the relay blade, and rewire the car stereo properly.
jivago
Jun 21, 2019 09:08 PM
Spudchucker
Apr 13, 2014 10:15 AM
nkinkade
Feb 28, 2014 08:49 PM
FlyingVee
May 29, 2013 06:05 PM
bossboy2
Mar 8, 2011 04:42 AM
