740 Not starting need advise
Old Jul 22, 2007 | 11:31 AM
gabyman97596's Avatar
Default 740 Not starting need advise
Ok so is a 1990 740GLE yesterday the car doesn't wanna start I found out that fuel fuse was out I replaced it with a anew one the car did start but it immediately turn off and doesn's wanna start again the fuel pump relay its new, coil its fine spark plugs has 1 month what should I cheeck I know the check engine light was on, it was the code on slot 2: 221,321 and on slot 6 143 the car was running perfectly don't know what could be the problem any help would be appreciate it thanks in advance
Old Jul 22, 2007 | 11:59 PM
VolvoDriver's Avatar
Default RE: 740 Not starting need advise
hello, i looked and offer these possibilities...
2-2-1: Oxygen Sensor (check or replace)
3-2-1: Cold Start Valve (check or replace)
1-4-3: Knock Sensor (check or replace)
check these items out and see what you cme up with. good luck.
gabyman97596
Sep 15, 2007 06:43 AM
gabyman97596
Sep 12, 2007 11:50 PM
m1964
Jul 10, 2006 09:25 AM
Ahmed
Apr 4, 2006 08:31 PM
terry
May 20, 2005 12:43 PM
