1990 740 PROBLEM NEED ADVISE
Old Sep 9, 2007 | 09:06 PM
gabyman97596's Avatar
Default 1990 740 PROBLEM NEED ADVISE
I have a 1990 740GLE I recently purchased a new oxigen sensor cause it was givin code 221(Heated Oxygen Sensor(Rich mixture/part throttle),it alsohas this code 321(Cold start valve-signal missing.) only that codeappear now, If I tried to erase it the red light start flashing very quickly and weird noises from the engine appear then it don't erase , I 've disconnected the negative cable on the battery to erase codes no chek engine light then after the engine start it starts a little misfire and the check engine light come on quickly what should about code 321 Do I have to replace air cold control valve or check cables or something like it any help would be aprreciate it thanks in advance.
_______________________________
Gabyman97
1990 740GLE
1992 240DL
1994 940TurboWagon
1999 S80 2.9
Old Sep 10, 2007 | 06:40 PM
Default RE: 1990 740 PROBLEM NEED ADVISE
Any advise for me????????????????????????????
Old Sep 11, 2007 | 11:01 PM
Beardog's Avatar
you should first check and see if the cold start valve is connected. it's indicating there is no signal. see if you get voltage from the cpu. unplug and then replug it in.
Old Sep 12, 2007 | 11:50 PM
Kruspe31's Avatar
i do not think it will affect drivability. all it does is injector more fule when the weather is under 60deg
mattem
May 14, 2020 08:39 AM
craigshensel
Jun 13, 2012 03:11 PM
gabyman97596
Sep 15, 2007 06:43 AM
gabyman97596
Jul 22, 2007 11:59 PM
terry
May 20, 2005 12:43 PM
