740 Power Steering Humming?
Old Dec 10, 2007 | 11:13 PM
colgate41's Avatar
Default 740 Power Steering Humming?
So i have had this problem for a while now. When it is cold and now even when its warm at times, my steering makes a strange humming sound. It happens when the steering wheel is stright. A humming noise is present, then when i turn the wheel it disapears. Any ideas? Maybe old fluid? Its a 91 740 turbo.
Old Dec 11, 2007 | 12:21 AM
iamnickcarter's Avatar
Default RE: 740 Power Steering Humming?
I'd drain and refill
Old Dec 11, 2007 | 08:42 AM
VolvoDriver's Avatar
I agree with the drain and refill. Use Volvo OEM power steering fluid, I used it and have had no issues, steering is emaculate...so far.
by the way, be VERY sure to bleed the system properly.
Old Dec 11, 2007 | 09:03 AM
jks2's Avatar
Make sure you don't have a leak in the system. If it is low because of leaking then flushing and filling will not take car of the problem. Also, is your alignment OK. If it is slightly off you may be turning the steering wheel slightly to keep it tracking straight. Not enough that you would notice it but enough to place the power steering pump under a load.
Old Dec 14, 2007 | 12:41 PM
colgate41's Avatar
I took some of the old power steering fluid out of the reservoir today and it was a murky color and didn’t look good. I put about a half a quart of new fluid in, it was the basic advance auto parts fluid and I know I just contaminated it with the old but I didn’t want it to be low. My question is, how do I go about draining and refilling the power steering fluid properly. The online guide here isn’t too helpful… http://www.swedishbricks.net/700900FAQ/FAQSummary1.html Also im having a hard time finding Volvo approved power steering fluid. Any ideas? Thanks guys. It’s a 91 740 Turbo 4Door
monkey113
Nov 7, 2007 07:36 PM
diehardgator1
Apr 19, 2007 11:46 PM
s80t6schcik
Mar 22, 2007 03:57 PM
SlavaD
Jul 31, 2006 11:56 PM
Low_Bridge
Aug 8, 2005 01:38 AM
