Humming sound
Old Apr 17, 2007 | 09:59 PM
diehardgator1's Avatar
Default Humming sound
I have a humming sound coming out of my dash sounds as though it is coming fm the radio It starts when you turn the switch key on and humms till several minutes after you turn the key off very annoying anyone have any thoughts on this? 2001 S80 2.9 non turbo I raised the hood and you cannot hear it It is coming out of the dash about where the radio is It does this even with the radio off
Old Apr 19, 2007 | 11:46 PM
Default RE: Humming sound
Just fixed it. The little vent on the dash board for the return air flow had gotten clogged with lint crud and what ever took a vacaum to it and you would not believe what I got out. Had to take a tooth pick and pull some of it thru the little grates. Put the vacaum over the hole as tight as possible and you will be surprised what is in that little hole
Vintage850
Apr 15, 2013 10:34 PM
KonaKula29er
Feb 19, 2012 06:54 PM
hairygerald
Jan 17, 2012 12:30 AM
thebigsee
Oct 17, 2011 07:12 AM
jkclaire
Dec 30, 2010 01:47 PM
