740 running ruff, exhaust rich
Old Oct 24, 2015 | 10:10 AM
  #21
lev's Avatar
lev
He doesn't need a ring job! Never seen a b230 with 200k to need a ring job!
May be '60's Ford or Chevy or a Dodge but not a b230...
Old Oct 24, 2015 | 11:45 PM
  #22
Old Time Mechanic's Avatar
Ok Lev. Your the pro. But I have only been working on cars, trucks sense 1972. So I guess I don't know nothing. I will leave with this. **** you very much.
Old Oct 25, 2015 | 11:25 AM
  #23
lev's Avatar
lev
Before quickly getting hot under the collar why don't you just wait to see how the case develops?
May be you should make some time to work on your manners and grammar skills while you are at it.
You obviously have been struggling with the English language since before 1972, and look at the results!
Old Nov 2, 2015 | 04:23 PM
  #24
fartoright's Avatar
Originally Posted by lev
Are the plugs wet with gas? Chances are they are contaminated just like your oil--change both!
Usually "run rich" is caused by too much air which sends a signal to the computer to send more fuel which doesn't get burned so it goes into the oil and fouls the plugs
Look for an air leak!
The air valve is NOT supposed vibrate.
Hey lev, been working and volvo has been sitting but i played around with it this past weekend. New info, while the car is running i unplugged IAC valve and the car stalled, plugged it in and car started and ran, does this mean the valve works? Also unplugged map sensor while car running and nothing happened. Starting at the back i unplugged each fuel injector individually and the car would start running really ruff and almost stall, the back 3 did this. When i unplugged the last one or the one closest to front nothing happened??? I checked that plug and it was dry and had spark. Also gas flew out of hole when cranking to check for spark, i made sure plug was no where near gas.
Old Nov 2, 2015 | 04:26 PM
  #25
hotplugging Bosch MAF/AMM's can fry things. I dunno about Regina MAP.
Old Nov 2, 2015 | 04:31 PM
  #26
fartoright's Avatar
Of course it would, i may just have to just take it to shop. I like fixing things myself but i may be over my pay grade
Old Nov 3, 2015 | 08:47 AM
  #27
lev's Avatar
lev
At this point I'd take a compression test to eliminate something serious like a valve problem. If the compression is OK, then you are looking at the cause of the misfire because this is what you have based on what you are reporting.
So far, seems like you have a problem with #1 cylinder...
Old Jun 19, 2017 | 07:59 PM
  #28
fartoright's Avatar
I never updated this post. Sorry. But the problem was bad #1 fuel injector.
drothelast
Mar 18, 2015 02:06 PM
dtech13
Jun 22, 2014 01:47 PM
89irocz
Jul 30, 2010 10:21 PM
kapelewski
Feb 16, 2009 09:49 AM
volvovolvov70
Jan 14, 2009 10:06 AM
