740 shuts off
Old Feb 27, 2016 | 09:05 AM
clockman's Avatar
Default 740 shuts off
I have a 88 740. Has been running perfect. Now starts runs great for 12 to 15 miles shuts off. Wait 30 mins starts runs12 to 15 miles shuts off. Here is what I find No fuel when trying to start. Here is what has been done Fuel pump and relay,main relay,amm,starter switch. I jumped across the fuel pump relay and the pumps run. I checked the main relay and it clicks. Battery is good, terminals and connections clean. It is like there is a bad relay that gets hot and shuts off, let it cool and it runs again. I am at a loss as what to check or where to look. Any help??
Old Feb 27, 2016 | 10:03 AM
lev's Avatar
lev
It could be the Hall sensor, the distributor pick up which goes bad. All the mentioned parts you replaced, like the fuel relay, is it an OEM? A lot of new parts for these cars are substandard and fail prematurely. One shouldn't assume that just because a part is new it's good.
Old Feb 27, 2016 | 10:17 AM
clockman's Avatar
Thanks for the reply. All parts I am using are coming from my 88 740 which was running perfect until a suicide deer killed it. I will swap the distributor and let you know. Thanks again!
Old Feb 27, 2016 | 04:24 PM
jagtoes's Avatar
Did you replace the radio suppression relay on the front of the coolant tank.
Old Feb 27, 2016 | 05:22 PM
clockman's Avatar
Kudos to lev!!! I swapped the distributor from my deer killer. It started as always, ran for 15 mins, shut it off and it restarted. Turned ito off let it sit, restarted. Did it again and started again. Proof will be road test tomorrow however the problem seems to be solved. Thanks and Kudos to all who helped this will keep my brick going for another 400k.
wouldbemechanic
Jun 24, 2015 08:51 PM
wallpaper42
Jan 17, 2010 01:43 AM
mbwittig
May 8, 2007 03:51 PM
L98Volvo
Mar 15, 2007 05:39 PM
oldmans90
Sep 17, 2006 01:08 PM
