740 water pump- advice
Old Jan 26, 2010 | 07:53 PM
belltv19's Avatar
Default 740 water pump- advice
Could anyone tell me what the best brand of a water pump for a
1991 Volvo 740 is.
in the last 4 years i'v changed the water pump 5 times, and every single one had a leak.
is it Genuine, Hepu, Meyle, GMB, Bosch or something else.
Thank you.
Old Jan 27, 2010 | 01:01 AM
Typhoon's Avatar
1991 Volvo 740 is.
Thank you.
5 times in 4 years is not the pump.
Regards, Andrew.
Old Jan 27, 2010 | 10:26 AM
blue goose's Avatar
Hepu. Are your belts too tight?
Old Jan 27, 2010 | 10:58 AM
bubba240's Avatar
Where has the leak been coming from?
Old Jan 27, 2010 | 06:20 PM
belltv19's Avatar
it's been coming from the O ring from the top of the pump.
and right now, the pump that i have is leaking from the
bolt at the botom of the pump.
Old Jan 27, 2010 | 06:21 PM
belltv19's Avatar
no, i don't think so. but i'll check it.
thanks.
Old Jan 27, 2010 | 07:10 PM
blue goose's Avatar
Have you been changing these pumps yourself? If so, the pump must be pushed up so the mushroom gasket mates with the head. Start the mounting nuts/bolts by hand then lever up the pump using a long screwdriver or something. Need to have that upward force while tightening the mounts.
Old Jan 28, 2010 | 10:42 AM
bubba240's Avatar
Plus having the mating head surface super clean will help the seal.
Old Jan 28, 2010 | 07:08 PM
belltv19's Avatar
thanks for the help. it helped a lot.
i'll try to follow your instructions.
Old Jan 28, 2010 | 09:42 PM
blue goose's Avatar
Brickboard FAQ:
http://www.brickboard.com/FAQ/700-90...ne_Replacement
majorcode
Nov 4, 2013 06:41 PM
Big Sam
Jan 30, 2012 02:19 PM
scrap88
Apr 7, 2010 09:23 PM
katiejoyful
Dec 12, 2007 04:49 PM
Erock198
Nov 16, 2003 08:59 PM
