83 240dl one front caliper seized
Old Mar 21, 2008 | 08:33 AM
Kaspir's Avatar
Default 83 240dl one front caliper seized
I need some advice on getting the driver's inside caliper free, the lower piston is stuck and when I removed the dust boot it was a bit rusty and closer inspection of the pad showed that hadnt been working for some time. Working on getting the car safetyd and would like to know how to free the piston, would rather fix then replace, I saw that volvo does sell a rebuild kit for the calipers need help soon car is on stands now
Old Mar 21, 2008 | 06:44 PM
240nc's Avatar
Default RE: 83 240dl one front caliper seized
go to autozone and get two new ones ... replace both sides ... it will be worth it
Old Mar 22, 2008 | 07:29 AM
Kaspir's Avatar
that's what I'm going to do, but having a hell of a time getting the brake lines free of the caliper body, one snapped already because it was twisting with the fitting. Do not want to snapp all of them, any tips or tricks to getting them loose with out stripping the copper nuts?
Old Mar 22, 2008 | 12:31 PM
blue goose's Avatar
Spray the fitting with PBblaster. Let it set for a couple hours. Spray it again. Get the tightest flare nut wrench that will fit and work the nut back and forth slightly to break the corrosion. Spray it again. Have patience. Consider replacing the brake hoses if they're twisted or swollen.
Old Mar 23, 2008 | 12:01 PM
Kaspir's Avatar
does any one know of a good source for oe parts, lowest quote so far for one caliper was $84 with core (in town here in winnipeg), cheaper on the net($55 with core)
natb
Jun 28, 2015 07:14 PM
mrlefler999
Engine & Internal
Nov 3, 2009 11:34 PM
Bruno937
Aug 19, 2009 05:21 AM
Kev75
Jan 2, 2008 08:54 AM
cameron
Sep 11, 2006 08:25 AM
