'85 240 Preventative Maintence - Radiator + timing belt
Hi all,
I am planning to replace my '85 240 DL's radiator, timing belt and water pump in the coming weeks. The radiator is leaking and the timing belt needs to be changed per the recommended 50k miles.
Is there any other preventative maintence I should look into doing while doing these jobs?
A lot of the old coolant stays in the system unless you drain the block and the heater. It may be a good idea to put fresh water, run the car with heater on til hot, drain it, once or twice before the final fill. The block drain in on the passenger side below the exhaust manifold toward the rear...
jesseh
2001-2013 model year V70
10-26-2016 09:48 AM
