85 245 Ignition switch completely locked up and steering wheel as well
Old Nov 3, 2018 | 02:29 PM
c.wilson's Avatar
Exclamation 85 245 Ignition switch completely locked up and steering wheel as well
I have a 1985 245 with the ignition switch and wheel locked up with a broken key.
Old Nov 3, 2018 | 03:38 PM
a locksmith or someone skilled in such things could perhaps remove the broken piece of the key with his picking tools.... otherwise, the lock core will need to be drilled out (not easy), then replaced with a new lock. I believe you can still order Volvo locks by your VIN from a dealer, so the new lock would use the same keys as your other locks, I've owned cars that needed different keys and its a pain.
Old Nov 8, 2018 | 07:27 PM
c.wilson's Avatar
Default 85 245 steering wheel/ignition lock
Thank you very much for the reply. It helped me out.
malcolm2
Feb 22, 2020 08:42 AM
moonshootr
Oct 9, 2009 04:22 PM
automatic1stdown
Mar 29, 2009 07:10 AM
kwolski700
Mar 24, 2009 07:57 PM
novablue69
Dec 28, 2006 09:57 AM
