87 240DL Overdrive is stuck "on"
Old Sep 6, 2007 | 02:15 PM
Midway's Avatar
Default 87 240DL Overdrive is stuck "on"
Im new to volvo and european cars altogether. My car is an auto with the overdrive switch being on the side of the shifter on top. I got in my car one morning to go to work and now the shifter seems to be stuck in the on position (overdrive light is on and car is in overdrive) is there an easy fix for this?
Old Sep 6, 2007 | 05:12 PM
Midway's Avatar
Default RE: 87 240DL Overdrive is stuck "on"
also, i did disconnect the battery from it and left it overnight and it is engaged and still wont turn off
Old Sep 7, 2007 | 08:44 PM
talbott357's Avatar
Have you tried checking the switch itself? I had one stick in the on position, and I sprayed it with an electrical cleaner, after that it worked fine. One other problem may be the overdrive relay is faulty, causing it to stay on also.
Old Sep 7, 2007 | 09:24 PM
Sounds like the OD relay is bad.
But when the light stays on the car doesn't go into overdrive.
Old Sep 7, 2007 | 09:40 PM
talbott357's Avatar
Good point, and one I forgot!!
Kyle Balents
Dec 9, 2014 01:00 AM
lilsilver85
Aug 29, 2014 04:07 AM
rmccotten
Feb 17, 2013 09:32 PM
ashlee
May 4, 2007 01:06 AM
benjamir
Oct 5, 2006 11:28 PM
