87 740 Gle Timing Belt
Old Oct 12, 2008 | 06:22 PM
iann3's Avatar
Default 87 740 Gle Timing Belt
i checked camshaft-wasn't moving, looked in top half of timing belt cover gear wasn't moving. i took top half of cover off & belt looks really cracked in certain places & the belt tension seems pretty loose but belt doesn't seem to be broken, maybe down in the bottom half of TBelt cover? can a worn loose belt (but not broken) have the same effect? I'm also concerned now after reading a couple of posts with engine damage what does it take to damage the engine with a broken timing belt?
Thanks
Ian
Old Oct 12, 2008 | 08:38 PM
Default RE: 87 740 Gle Timing Belt
Your engine will not bend valves.
I will bet the teeth are missing off the bottom section of the belt where it goes around the crankshaft.
bobm
May 14, 2015 01:16 PM
iann3
Oct 11, 2008 12:52 PM
Zebisko
Apr 16, 2008 12:49 AM
gordon .
Nov 26, 2007 04:40 PM
memken
Sep 7, 2006 08:55 PM
