87 740 sunroof
Old May 11, 2005 | 03:50 PM
dewrat's Avatar
Default 87 740 sunroof
I have an 87 740 GLE and the manual sunroof does not work the handle does not turn at all it is completely locked up any ideas on how to fix it?
Old May 11, 2005 | 04:43 PM
Default RE: 87 740 sunroof
It might be out of time.You can try removing the crank handle and check and see if you can move the cables.
Then reinstall the handle and try again.
Old May 14, 2005 | 10:22 PM
dewrat's Avatar
pulled off the crank and the plastic trim piece around it. it looks like the gear that the handle connects to is just constantly spinning. there are little spurts of resistance in it but for the most part it just spins. also how would i go about taking the headliner off to access the sunroof itself?
Old May 15, 2005 | 01:28 AM
Under the handle should be the 2 cables.The gear hits and pushes the cables open and closed.
You will have to remove the trim and the interior light to get it to drop.
It has been a while since I had one out.Once you remove the trim peices and everything else screwed into the roof it should drop down.
Old Jun 20, 2009 | 12:45 AM
buellfire's Avatar
This is the same thing that happened to us - we just replaced the headliner so we took the whole thing apart - it looks good but I think that the actual gear is stripped out - because once it catches, it will open and close - it just takes a lot of turns!
Where can I get a new gear to try to replace it?
phatboy130
Oct 31, 2006 09:16 PM
phatboy130
Oct 11, 2006 03:03 PM
pmvictory
Jul 31, 2005 11:29 AM
digitizzle
Jun 25, 2005 09:30 PM
TheVolvoMan
Dec 6, 2004 01:42 AM
