87 volvo cruse control
Old Oct 16, 2015 | 11:40 PM
mjohansson2's Avatar
Default 87 volvo cruse control
Ok, so I took out the cruse control from a junk yard 240 '88 vintage. The one part I did not get (I hope it's only one part!) was a cable that runs from the transmission to the same place the throttle cable goes. Is there a difference between the cable for a Auto transmission and a 5 speed manual?
Old Oct 17, 2015 | 01:01 AM
lev's Avatar
lev
Should be the same.
Old Oct 17, 2015 | 12:56 PM
a manual transmission doesn't have a throttle pressure cable
Old Oct 17, 2015 | 03:37 PM
lev's Avatar
lev
True, true, true... The 5 speed wouldn 't have that cable...
Old Oct 18, 2015 | 10:15 PM
Default 87 cruse..
Hey cool! so ok I tried to install the bracket under the steering column and it is not a very good fit, the bracket has some soup can sized vacuum servo and cable to the gas pedal attached. But there is a silver component on the clutch pedal in the way, and I don't want to bend, damage or? maybe I need a different bracket as the one I have did come off a car with a automatic and mine has the clutch pedal that maybe is now in the way.? any of you know any thing about this?
Thanks, and God bless.
mike
Old Oct 18, 2015 | 10:24 PM
cruise control for a manual is slightly different than for an automatic... there's an additional cruise 'kill switch' on the clutch.
Old Oct 18, 2015 | 11:03 PM
lev's Avatar
lev
There's a second vacuum dump switch on the clutch pedal identical to the one on the brake pedal for disconnecting the cruise by depressing either pedal.
Old Oct 20, 2015 | 08:16 PM
Default 87 cruse
Ah gee...I have gone to two different supposed Volvo specialist shops that actualy have some Volvo junk cars in there back lot, and neither of those folks have even seen a 5 speed manual with a cruse control! and of course all the junk yards around here don't have one either! just my luck. Even E-bay has several units but all for the 90-93 models or they cost more then the car did. Bummer
Old Oct 20, 2015 | 09:25 PM
lev's Avatar
lev
Just get another brake pedal switch and install it on the clutch pedal with another vacuum line and a T fitting, OR, do without it, just remember that your clutch pedal WILL NOT disengage the cruise--no big deal! The cruise kit is the same for manual and auto, at least on the 740/940 lines, may be different on a 240.
Old Oct 21, 2015 | 01:34 AM
afaik, there were more 240's with the M46 4-speed + OD than with the 5-speed
[my volvos have all been AW7x slushboxes]
Old Oct 21, 2015 | 07:29 PM
lev's Avatar
lev
So what? The CC should be the same for both trannies...
otis44
Jun 24, 2024 03:30 PM
cbevis
Feb 15, 2013 02:52 PM
Platinum52
Jul 17, 2009 07:33 PM
jfikentscher
May 31, 2006 09:58 PM
