88 740 gle transmission sounds
Old Apr 4, 2009 | 02:55 PM
kamaradalex's Avatar
Default 88 740 gle transmission sounds
Hi guys,
The transmission has always been long on shifting, it was making a klunk sound, like it was hitting the inside box or something, between gear. But it went louder and louder, and now when I stop, ther is a another klunk sound and the same kind of hit from the back of the car. Any ideas about it ? What can I do ?
Thank's a lot
Old Apr 4, 2009 | 07:27 PM
blue goose's Avatar
I would have a mechanic take a look at the universal joints. A Volvo mechanic, preferably an independent Volvo mechanic, or the dealer if that's all you got. Definately not a national franchise shop. Also I would check the tranny fluid to see if it's the proper level and if it's brown or burnt. You don't say what kind of a tranny it is and I'm guessing AW70/71.
Old Apr 4, 2009 | 11:16 PM
tedv's Avatar
It's not a u-joint if it's happening while down shifting. Check the fluid and if that's not low or really bad, your tranny is bad.
Old Apr 5, 2009 | 08:49 PM
1990TURBO740's Avatar
Sounds like a worn, loose or broken trans mount or a bad U-joint...possibly a bad motor mount letting the trans move around a bit?
Old Apr 8, 2009 | 02:09 PM
Thank's guy for the reply, I'll check the fluid and I'll have to go see a mechanic to investigate the problem, cause I never fixed a transmission.
Thanks again !
steelheaddan
Feb 5, 2011 06:54 PM
jenhardy
Feb 1, 2011 12:36 AM
knoman
Jun 23, 2009 08:56 AM
greatnorthern740
May 22, 2007 03:46 PM
TedH
Mar 20, 2006 08:32 PM
