88' 740 Turbo no hot starts
Old Jun 29, 2017 | 11:46 PM
Blakedd20's Avatar
Default 88' 740 Turbo no hot starts
So I've been working on a 88' 740 Turbo for a few months now, and its running now, but its running hot. Fires right up every time, but after driving a short distance, say 2 miles. i'll turn the car off and when i go to turn it back on, the engine cranks but there is no sign of the engine starting. It will just sit an crank, the engine is getting very warm, after about 20-30 minutes the 740 will start right back up. cant seem to track down the issue.
So far I've replaced: Radiator, put in an 88 degree thermostat, Fuel injection Relay, Noise suppression relay, in-line fuel pump & filter, In-tank fuel pump, thermostat, and air filter. i also recently went through and changed out all my auxiliary belts, and timing components.
Old Jul 1, 2017 | 10:36 AM
madman77's Avatar
Ok, lets try one thing at a time. When it's engines hot and will not fire are you getting spark at the plugs? If not ,try and spray some "Canned air" like they use to dust off keyboards on the ignition module and see if it starts then,if it does then you know that the module is faulty .
Old Jul 1, 2017 | 01:22 PM
in addition to checking for spark, check for fuel... when its cranking, can you smell fuel vapors at the exhaust pipe? plug a 'noid light' into an injector, crank, does the noid light blink? is the fuel pump running right after you've cranked (it should stop about 1 second later)?
Old Jul 6, 2017 | 08:39 PM
Blakedd20's Avatar
I'll be able to update in a few days. Not in town for a bit, but ill for sure try this out and let ya know. Thanks for the help!
LNZ06XC70
2001-2013 model year XC70
Jun 10, 2021 09:17 PM
louisejohnsen
Nov 6, 2013 07:12 PM
newmex999
Jul 4, 2013 03:05 PM
KatieK
Nov 11, 2010 10:29 PM
beardo265
Sep 27, 2007 09:24 AM
