'90 240 hard to start on low fuel but now turning over fine.
Old Sep 25, 2014 | 05:19 PM
jherguth's Avatar
Default '90 240 hard to start on low fuel but now turning over fine.
My 1990 DL wagon ran out of gas today. When I filled the tank back up to about half and tried it the following would occur:
backfiring
crank, then a total power loss mid-crank, then cranking again.
It finally started up again after one of these power dips and idled until I put it in gear. Stalled immediately when i let up the clutch. After 3 more starts and stalls and about 2 hours I finally got it running and back to the house.
Once it was home it would turnover every time free of issue, however, it is now sounding pretty loud almost as if there is a new exhaust leak.
I also noticed one of the wires on the o2 sensor has broken off. Does this sound like an o2 sensor issue or a combination of things?
Ive not checked any codes.
Old Sep 26, 2014 | 06:56 PM
lev's Avatar
lev
o2 sensor cannot cause any of those symptoms. i can't see how running out of gas can trigger an exhaust leak... may be a fuel pump issue, the running problems you describe, ok, but not an exhaust leak. probably just coincidental.
Jerry Balch
1998-2000 model year XC70
Feb 15, 2014 11:51 PM
mrdude888
Dec 17, 2010 06:56 AM
Riculus
Nov 7, 2009 12:01 PM
saltmiser
May 5, 2009 08:08 PM
furball3
Jan 28, 2007 03:31 AM
