90 240 misses around 2500rpm
Old Jun 30, 2008 | 10:58 AM
BorninBflo's Avatar
Default 90 240 misses around 2500rpm
90 Volvo 240 with 282,000 miles, standard trans, mostly original (proudly replaced original clutch at 278,892), misses slightly around the 2500 rpm range in all gears. It hasn't affected mpg and the miss isn't severe but irritatingly noticeable. I'm not sure if it's related but when I'm low on gas it is hard to start. As soon as I fill up - it's back to normal. I've run Techron through it, replaced the fuel filter, plugs rotor and cap replaced, new air filter, cleaned intake. Someone said crank angle sensor(?). Any ideas would be appreciated?
becketts
Feb 18, 2010 11:35 PM
sia
Sep 7, 2008 04:27 PM
ciao-rich
Jun 13, 2008 05:01 PM
pconfar
Dec 10, 2007 06:11 AM
