90 240 Neutral Safety Switch replaced but car still will not start in park
Old Aug 24, 2013 | 11:57 PM
jonqu's Avatar
Default 90 240 Neutral Safety Switch replaced but car still will not start in park
I just replaced the neutral safety switch (NSS) in my 1990 240 because the car would not start at all. Now, the car starts (most of the time) with the shift lever in neutral, but will not start when in park. I'm thinking I was shipped a bad switch. Could there be another cause?
Thanks!
Old Aug 25, 2013 | 02:45 PM
Thanks!
incorrectly installed, or badly worn pivot bushings ? just guessing.
Old Aug 26, 2013 | 10:57 AM
jonqu's Avatar
The NSS that I installed was new (at least I think it was). As for the installation, that is entirely possible. I think I got the metal pin that comes off the shift lever in the correct location in the switch, but I will check again this weekend.
Is there a way to remove the gear shift **** on an automatic?
Old Aug 26, 2013 | 12:58 PM
the pivot bushings I was talking about are on the main shift arm. when they wear out the arm gets sloppy
Old Aug 26, 2013 | 08:22 PM
jonqu's Avatar
Are the bushings inside the compartment where the shifter terminates on the inside of the vehicle?
Old Aug 26, 2013 | 08:31 PM
the main shifter pivot bushings are, yes. there's also bushings on the linkage joints outside
mcadek
Jul 24, 2015 01:08 AM
AnEskimo
Jun 11, 2013 08:15 AM
petes99xc
Feb 10, 2007 10:24 AM
tngreg
Jan 4, 2007 08:50 PM
Red XC
Jan 20, 2006 08:34 PM
