How do you bypass the neutral safety switch in a 240 with A/T?
Old Jun 10, 2013 | 12:04 PM
AnEskimo's Avatar
Default How do you bypass the neutral safety switch in a 240 with A/T?
Hello, I am working on a 88 or 89 240 wagon that wont turn over at all. I replaced the starter and nothing changed. My best assumption is the neutral safety switch is bad, but I don't have the time/resources/parts available to replace it at this time. I have found a few post about bypassing this switch which will allow the car to start. Can anyone provide me with some good instructions on where I locate the wires to jump? is it at the starter or the switch itself? Colors and/or pictures would be greatly beneficial if available! If not, a good description will help me get started and I should be able to figure out the rest. Thanks.
Old Jun 10, 2013 | 12:14 PM
piv15's Avatar
The location of the switch is under the cover of the shift stick. Once you remove that, look to the right of the shifter. There are a couple of screws to undo, then you must wrestle the switch out. The switch is kind of triangular looking, and has a white pointer sticking out of it. When mine was bad, I bent back all the Metal tabs to try and clean it, but I ended up breaking mine. So, I used the white pointer, lined it up to the contacts as though it were in park, and my car could start.
Old Jun 10, 2013 | 07:17 PM
AnEskimo's Avatar
I ended up just running a lead from the battery and another from the spade on the starter for the neutral safety switch into the car through the fire wall and plugged it into a push button switch. Works for now, just turn the key on and hold the button down!
Old Jun 11, 2013 | 02:00 AM
piv15's Avatar
Haha... When mine was broken, I had to line the pointer up just right while holding the key to start. It was somewhat tedious! A button is upscale compared to what I had haha. Anywho I fixed it. Got a switch off of FCPEuro.
Volvo Neutral Safety Switch (240 260) - KAE 9130035 | FCP Euro
Old Jun 11, 2013 | 08:15 AM
for future reference, the park/neutral safety switch should have a plug along the side of of the tranny hump forward of the shifter, you could unplug it there and jumper the wires together.
jonqu
Aug 26, 2013 08:31 PM
troutfanatic
Jul 14, 2012 08:21 AM
nuthinbutmacs
Oct 8, 2011 04:20 PM
petes99xc
Feb 10, 2007 10:24 AM
Red XC
Jan 20, 2006 08:34 PM
