91 740 sedan washer pump
Old Mar 14, 2009 | 07:32 AM
hairyg's Avatar
Default 91 740 sedan washer pump
The washer fluid reservoir is full but no fluid pumps out. Is the only possibility the pump, or could it also be the filter, nozzles, ??? The pump looks corroded. Is it possible it is just dirty and can be cleaned and reusable? What is the smartest procedure to go about diagnosing the problem?
Thank you for any advice and knowledge you can give.
Hg
Old Mar 14, 2009 | 01:21 PM
fredbyte's Avatar
Use a staple to clean out the nozzles. Next, clean contacts on washer pump. Try running. If no go, check for voltage to pump leads.
Old Mar 14, 2009 | 03:03 PM
blue goose's Avatar
Washer pumps often getted gunked up because of infrequent use and hard water. You can take the pump apart and clean the gears. Or just replace the pump. Best to use windshield washer fluid and use the pump at least once a month.
Old Mar 15, 2009 | 08:04 AM
hairyg's Avatar
THANK YOU VERY MUCH!
hg
97black850
May 27, 2021 09:49 AM
huzzsaba
May 12, 2021 02:03 AM
volvoQ's
Sep 26, 2010 01:45 AM
info2x
Feb 4, 2006 04:45 AM
blahop
Dec 5, 2005 08:59 PM
