'91 740 Simultaneous codes 232, 132 Regina
Old Jan 16, 2016 | 05:02 PM
volvo_duo's Avatar
Default '91 740 Simultaneous codes 232, 132 Regina
We just got our first check engine light in many years. It appears that we have a Regina system so I extracted the codes for it.
232 is an O2 sensor but 132 is a voltage high/low
I'm suspicious that with both codes being thrown at once, the problem might be something else.
Is 132 an injection system voltage error or general battery/charge system? Any thought on what might cause both codes at the same time?
Thanks.
Den
Old Jan 16, 2016 | 08:52 PM
lev's Avatar
lev
Any drivability problems/symptoms? I'd first reset the light by disconnecting the battery for a few minutes, see if it comes back. The OBD is far from perfect, any electrical glitch may set off a code without any further issues.
Old Jan 16, 2016 | 10:31 PM
volvo_duo's Avatar
I was able to reset the codes and got a 1-1-1 return. As soon as I started the engine the check engine light remained on. Tomorrow I'll disconnect the battery and see if the results are different.
The car has had a tough time idling on very cold mornings but I blamed the need for new plugs and perhaps wires for that.
No other symptoms. Ran fine today after starting the engine above.
Old Jan 17, 2016 | 01:04 PM
lev's Avatar
lev
Well, if you need a "tune up", a good way to start... Use NGK plugs and Bougicord wires to make sure those are not the issue...
evanernest
Feb 4, 2015 12:16 PM
Islandgirl806
Nov 15, 2013 08:50 AM
gregseto
Aug 7, 2009 07:14 PM
new850driver
Jan 12, 2008 06:46 PM
Lucky_Avalon
Engine & Internal
Jul 20, 2006 12:58 AM
