91 745 turbo turbocharger
Old Mar 28, 2010 | 03:37 AM
enigma4you's Avatar
Default 91 745 turbo turbocharger
Hi, this is my first post to this forum.
I have a 91 745 turbo that I have owned for a number of years. We parked this car about 3 years ago, at that time it had stopped shifting into 4th gear and was blowing some smoke.
My son and I decided t oget it on the road again. It did start with very little trouble and after a good washing everything was as it should be.
We have a few problems, the turbo needs to be rebuilt, not a problem but it the process off taking it apart the turbine shaft broke leaving only 2 threads. my plan is to have it welded and rethreaded, however if a replacement tubine is available I would like to replace it. Has anyone had to buy this part? If so where from? I would also like to find a good rebuild kit for the turbo. any recomendations?
Next is the sunroof. it was leaking and we pulled it out, we found that is has a broken guide. I need to find that part. so again if anyone has a source?
I think the tranny problem is a seliniod, my plan is to just remove it and put in a plate.
Thanks in advance for the help. I have a very strong mechanical background so I am not real worried about how complex something can be.
Aleks
May 3, 2013 02:22 PM
keenv70
Jun 1, 2011 11:10 PM
russ g
Jan 23, 2011 07:50 PM
steveb8699
Oct 5, 2006 07:12 PM
thesaintnr1
Mar 17, 2006 01:33 AM
