'91 940 turbo, no A/C
Old Oct 29, 2006 | 10:22 PM
DJboozeAlot's Avatar
Default '91 940 turbo, no A/C
just bought a '91 940 turbo, and the a/c doesnt work. the compressor isnt coming on.
how can i tell if it has been converted to r-134a? and where is the schrader valve for the low side?
also, where is the relay located for the a/c and how can i test that?
Old Oct 29, 2006 | 11:36 PM
Default RE: '91 940 turbo, no A/C
The schrader valve should be next to the dryer.
If there is a funny looking connection at the dryer it should be converted.
Unplug the low pressure switch at the dryer and jump it with a wire with the car running and see if the compressor kicks in. If it does then most likely you are low on freon.
Old Oct 30, 2006 | 04:56 PM
can you tell from these pictures if it has been converted to r134a? and what does the low pressure switch look like, can you see it in these pictures?
Old Nov 2, 2006 | 10:01 PM
That is still R-12.
The low pressure switch is the thing screwed into the Dryer(Aluminum cylinder) That has the plug that goes to it.
pburchins
Aug 27, 2010 08:20 PM
ogotaj
Mar 22, 2008 02:57 AM
MikeQ
Jun 11, 2006 11:26 PM
saleen
Oct 13, 2005 09:52 PM
dece207
May 6, 2005 12:47 AM
