92 240 Transmission Question.
Old Apr 19, 2013 | 03:49 PM
IFGD's Avatar
Default 92 240 Transmission Question.
I just bought a 92 240. Car drives great once you get going, but getting going from a dead stop is a little slippery.
If you're really easy on the throttle, you'd never notice it. Anything beyond that and the transmission slips when you try to get the car moving. Once its got a little bit of momentum, the trans shifts perfectly.
Any advise? How easy is it to find used/rebuilt transmissions for these cars?
Old Apr 19, 2013 | 04:44 PM
lev's Avatar
lev
Try changing the trans fluid. If that doesn't work, used trannies are available all over the place--better than rebuilt.
Old Apr 19, 2013 | 05:19 PM
IFGD's Avatar
I just checked the fluid. Dry as a bone.
Could it be just a leaky pan seal? What would be the possible causes of a dry transmission?
Old Apr 19, 2013 | 09:35 PM
lev's Avatar
lev
Leakage. Fill it up, see what happens.
Just because it doesn't register on the stick it doesn't mean it's empty, it's LOW. If it's been a long time may be there is no major leak. You should change it anyway, not FLUSH it, just change it.
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
n2umr
Dec 2, 2004 10:01 AM
