Timing gear belt
Old May 19, 2005 | 03:28 PM
jamescambron's Avatar
Default Timing gear belt
I just bought a '93 240 with 165,000 miles on it. There is no way to tell if the timing gear belt has been changed in the last 100,000 miles. I had a timing gear belt blow on an 850 and it warped my valves and cost a bundle to repair.
I have been told that on the 240 that the timing gear belt when blown will not cause the damage that was done to my 850. Should I replace this part before it breaks, or replace it when needed?
Thanks,
Old May 19, 2005 | 07:51 PM
Default RE: Timing gear belt
You can pull the upper cover off and look at the belt.If it has any cracks at all replace it.
If the belt breaks it will not cause any damage.You can just put a new belt on and start it up and go.
Old May 19, 2005 | 10:21 PM
Thanks for your help. I will check the belt this weekend.
Old May 19, 2005 | 11:18 PM
If you need anymore help just let us know.
Old May 22, 2005 | 09:17 PM
Thanks, Tech...I will.
mexicanfooddude
Apr 15, 2015 06:46 AM
SoK66
May 2, 2014 05:39 PM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
