92 740T have independent rear?
Old Mar 22, 2005 | 02:40 PM
jc740T's Avatar
Default 92 740T have independent rear?
I was looking into a pair of bilstien shocks stated to be compatible with all 700/900 series except those with independent rear. Does 92 740T wagon have an independent rear? Thanks.
Old Mar 22, 2005 | 04:18 PM
Default RE: 92 740T have independent rear?
I forget when they changed them.You can look under the rear of the car and tell easy.Look under the rear of the car if it is a solid axle it is a big metal tube that goes from one side to the other.If you have independant rear suspension then it will look like axles out of a front wheel drive cars.There will be a rubber boot on the inside and outside of the axle on each side of the car.
Old Apr 17, 2005 | 07:49 PM
mr's Avatar
mr
Would a 91 740 turbo Manual Trans, have IRS? I don't have one so I can't just look under the car.
Old Apr 17, 2005 | 08:20 PM
I think the 91 740 was still the solid rear axle.I am not 100% sure but it should be the solid axle.
pierce
Jan 10, 2011 07:36 PM
rooster11
Sep 20, 2010 10:30 AM
960 rookie
Nov 12, 2007 06:39 PM
mevans42
Sep 8, 2005 09:30 PM
randyjoy
Nov 7, 2004 08:23 PM
