multi-link vs. independent rear suspension?
Old Nov 7, 2007 | 07:02 PM
960 rookie's Avatar
Default multi-link vs. independent rear suspension?
Hi-
I'm new here, and I have a question about rear suspension. I understand that earlier 960's came with solid rear axles, and newer ones came with independent rear suspension- but what is the difference between independent rear and multi-link suspension, and how do I know which one I have on mine? It's a 97 960.....
Bottom line is what I am really looking for is to replace the rear brake rotors and pads, but it supposedly matters what suspension you have....
Old Nov 11, 2007 | 03:43 PM
960 rookie's Avatar
Default RE: multi-link vs. independent rear suspension?
Ok, so the answer is that there is no difference- multi link and independent suspension are one and the same thing.
Old Nov 11, 2007 | 06:48 PM
No they aren't
Multi link is independant both sides have control arm and C/V axles. Your will have that.
Solid axle is a solid tube. Which was pretty much done away with in late 1993 or 1994.
Old Nov 12, 2007 | 06:39 PM
960 rookie's Avatar
Yes, but I was asking about the difference between multi-link and independent, not multi link and solid. Several parts houses list pads that would lead you to believe that there are 3 types- multi link, independent and solid.
In reality there is only solid axle on the early ones and multi link (which is independent) on the later ones. I ended up with the right ones by looking at them first before going to get the new ones.
Thanks for the responses.
rooster11
Sep 20, 2010 10:30 AM
nattyderek
Jul 15, 2009 09:05 AM
TedH
May 6, 2008 09:49 PM
jc740T
Apr 17, 2005 08:20 PM
randyjoy
Nov 7, 2004 08:23 PM
