92 volvo 240 driver high beam not working
Old Nov 25, 2016 | 07:24 PM
xDread92x's Avatar
Default 92 volvo 240 driver high beam not working
Hey guys finalizing some minor things on my 92 wagon I picked up. I just put in new head light bulbs and for some reason the driver side bulb goes out at high beam. Any ideas?
Thanks!
Old Nov 25, 2016 | 07:44 PM
the high beams are wired together to the step relay output, so if one is working, adn the other isn't, its the wiring or socket or a bad bulb.
the step (high/low) relay is near the left headlight, pin 56a has a red and a white-red wire... the white-red one goes to the instrument panel high beam indicator, while the red one goes to a harness splice that goes to red wires to both high beams... if one high beam (and the indicator) are working, that suggests the relay is fine, so the problem is only in the wire specific to the left (drivers) headlight and/or the connector on said headlight, OR you got a bad headlight.
Old Nov 26, 2016 | 04:13 PM
xDread92x's Avatar
Appreciate the response.
I disconnected the relay and cleaned connections, etc. Plugged it back in and both high beams work now.
Thanks!
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
philk
Oct 21, 2020 02:21 PM
bikeluver43
Oct 2, 2014 07:10 PM
Volvoguy505
Sep 11, 2010 05:53 PM
adame780
Aug 26, 2005 08:30 PM
