'93 240 Power Doors won't lock
Old Jun 18, 2009 | 09:05 PM
alexdelove's Avatar
Default '93 240 Power Doors won't lock
Strangely enough my 1993 240 Wagon power doors refused to lock today with looking of the drivers side door with a key. Opening up all doors works fine, but closing the door with a key the other 3 doors ***** and rear door don't move up down and lock. Not a fuse, since opening works and checked the fuse. And doesn't seem like a relay problem since they open fine.. or maybe not?
Any thoughts, tips, experiences will be appreciated as I keep looking for the culprit.
Thanks in advance,
Alex...
Old Jun 19, 2009 | 07:30 AM
adub96's Avatar
I had the same problem, spite mine being a 2 door. I took it all apart, cleaned everything up and put it back to gether and it worked. Might work for you...
Old Jun 19, 2009 | 09:21 AM
tedv's Avatar
Sounds like an actuator problem, the one in the driver's door... kind of a pain to change. My '92 940 needs that one changed, too. This one LOCKS all the locks when you try to open the door after sitting for a few minutes-bad gas station experience!
Old Jun 22, 2009 | 07:47 AM
alexdelove's Avatar
Default Fixed!
Thanks guys for your suggestions! Problem ended up being a broken wire (red) in the driver's door going to the locking relay. Wire broke at the door hinge point, where the volvo wires usually break.
Lessons learned:
1 - start troubleshooting at the source to destination. Checking locking/unlocking relays may have seemed like a easy idea but taking apart the dashboard/instrument panel is no easy task.
2 - make sure to remember where all the screws come from. Two (2) 1-inch allumimun machine screws (~ 1/4" diameter) are left over after the assembly. Anyone know where they may have come from? Driver-side door and instrument panel were dissassembled/assembled.
Alex...
DHC5tech
Mar 5, 2014 07:22 PM
crgolf
Feb 10, 2013 12:43 PM
Akaly
Jul 1, 2011 09:04 PM
mmnewcomb
Apr 27, 2011 08:28 AM
JKinPA
Nov 14, 2008 08:40 AM
