93 240 Rear Cam Plug (seal)
Old May 24, 2015 | 10:09 AM
lionhearted1's Avatar
Default 93 240 Rear Cam Plug (seal)
Found plugged line from throttle body to flame trap, repaired. But blew out rear cam plug. Does plug just push in? Read somewhere that rear cam cap has to come off to replace seal. Looked on back of head, it's just a circle with end of cam showing. If the new one needs to be pushed in, does it go in flat side towards cam or the lip side towards cam?
Thank You All
Richard
Old May 24, 2015 | 10:13 PM
REVOLV's Avatar
You should just be able to lube it up and press it in. If it really came down to it, you would just have to pull the valve cover, not the rear cam cap, to get it to seat well. IPD sells a retaining plate. I have one in my engine, but not sure that it even does much of anything when the plug has been installed properly.
Old Mar 28, 2023 | 03:23 PM
rayos-x's Avatar
Plug does just push in, but it's much easier if you pull the rear bearing cap. It then just drops in, and the cap squeezes it a little as it's bolted down. I'm ordering the IPD retainer just in case, if the flame trap or related tubing clogs, pressure can build up and pop it out...
Jimal
Apr 15, 2013 03:54 PM
jmcconnell
Jun 24, 2011 01:57 AM
arrow
Feb 26, 2011 03:33 PM
Dsssurf
Jul 1, 2010 12:04 PM
WalterXI
Apr 9, 2010 01:36 PM
