valve adjustment
Old Jun 29, 2006 | 11:47 PM
browntrout's Avatar
Default valve adjustment
I've done valve adjustments on an old Meercedes that I had. I was wondering if doing one on my 740GL is similar. On the Merc. I would check the clearances with the cam lobe and rocker arm with the lode straight up. Is this similar on the B230F? Does anyone know what the clearances should be?
Old Jun 30, 2006 | 12:20 AM
Default RE: valve adjustment
Look on the Cam shaft and find the lowest point usually the lobe will be pointed at like 11 or 2.
The clearance should be .30 to .40 cold engine and .35 to .45 warm engine I always use a 16 and 19 fuller guage and if 16 fits and 19 doesn't it is fine. If 19 fits then it needs to be reshimmed.
Old Jul 2, 2006 | 03:08 AM
browntrout's Avatar
so the gap is the same for exhaust, as it is for intake? what is recomended for turning the engine over during the adjustment? thanks, scott
Old Jul 2, 2006 | 10:52 AM
A 24mm socket on a 1/2 drive ratchet turning the crank pulley.
Hookem
Oct 3, 2010 10:04 PM
nextproject
Nov 16, 2009 07:04 PM
mygreenbomb
Feb 29, 2008 06:09 PM
dsniner
Dec 23, 2007 12:12 AM
v62cobra
Jul 28, 2006 02:00 PM
