93 940 need engine help!
Old Dec 23, 2008 | 03:29 PM
wento's Avatar
Default 93 940 need engine help!
Just bought used '93 940 no turbo 171k miles drove about 3 days no problems then while on interstate the engine went to max RPM. I could slow down the vehicle but engine is fighting to go max speed. I tried everything I could put my hands on, like throttle cables, throttle body, butterfly valve, cruse control etc.they all seem to be working freely. If I start the engine, wether cold or hot, it goes to max rev. I can't affect this symptom in any way except to shut it off. I'm desperate, I don't even know where tobegine to look fora solution. No one seems toeveanhave heard of this problem.
Old Dec 24, 2008 | 12:22 PM
billofdurham's Avatar
Default RE: 93 940 need engine help!
Welcome to the forum.
Have you checked for fault codes using the on board diagnostic unit in the engine compartment?
Old Dec 25, 2008 | 01:55 PM
wento's Avatar
No not yet, my first Volvo. How do I do that? Ho do I read the codes?
Old Dec 26, 2008 | 01:33 PM
This is a full how-to which does cover your car. Some of the codes may be different as you have a non-turbo. Anything you don't understand post here.
http://www.matthewsvolvosite.com/for...c&start=12
Old Dec 26, 2008 | 03:58 PM
wento's Avatar
Thanksfor the infoabout the diagnosticunit. I ran the test as you discribed and got a 1-1-1 code, but the condition still existes. I bought the Chilton manual and I see that there is a lot of electrical components assoeiated with the fuel system, but no idea which onemight be a likely cause. Any ideas? Meanwhile I'll be reading the manual. Thanks again
Rudi
Aug 18, 2010 09:36 PM
Sanel30
Feb 18, 2010 09:16 PM
chef
May 19, 2009 05:57 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
joker834
Nov 15, 2006 10:21 PM
