93 940 wagon oil leak return
Old Aug 7, 2005 | 06:38 PM
GaryBrad's Avatar
Default 93 940 wagon oil leak return
Well I thought I fixed my original oil leak with a flame trap replacement but now I have it back again. It drips from the fly wheel shield. Is that normaly a main seal leak? If so, is it a matter of unbolting the transmission and dropping it enough to reach the seal and replace it?
Old Aug 7, 2005 | 09:36 PM
Default RE: 93 940 wagon oil leak return
Sounds like the rear main seal to me.You will have to remove the trans and then the flywheel to replace the seal.
NOTE: If you do it mark the Flywheel before you remove it.
Old Aug 12, 2005 | 12:48 AM
GaryBrad's Avatar
Thanks Tech
I bought the seals today for both the rear of the motor and the front of the transmission. Remind me again of why and where I should mark the flywheel. Also is there any other things to remember when I pull the tranny while I am there. I assume I should rent a tranny jack, remove the drive shaft and cross member, take off the fly wheel guard and then what should I find or do next. Just unbolt the transmission? Sorry for all the questions but it is my first time working on a volvo tranny.
Thanks Gary
PAVolvo850
Jul 22, 2012 04:00 PM
sparro
Oct 11, 2011 01:27 AM
pburchins
Aug 27, 2010 08:20 PM
redbottle
Nov 5, 2009 09:41 PM
v70 2.4t
Mar 1, 2006 02:21 AM
