'94 940 speedometer malfuntion
Old Nov 28, 2016 | 10:46 PM
Oregonite's Avatar
Default '94 940 speedometer malfuntion
The speedometer in my '94 940 only works when I start driving after it sits overnight then quits after about the first 1/4 mile of driving. Do you think it is the sensor on the rear-end? The ABS light does not come on. I checked the wiring that come out of the sensor and the wires are not broken. The problem started after I had rear brakes and new rotors and calipers put on it, the installer hit the old rotors with a hammer straight on the end of the axles with a 3-5 lb. hammer to loosen the rotors. Would that damage the sensor on the rear-end by any chance? Or it might be a coincidence. Is there a chance of corrosion at the connections of the harness? What is the easiest way to troubleshoot the sensor?
ctphil
Jun 1, 2022 12:05 PM
my92940GL
Dec 28, 2015 04:22 PM
NCVOLVO940
Jan 7, 2011 05:23 PM
janeofdrama
May 24, 2010 08:02 PM
doudah
May 24, 2009 07:53 PM
