'94 940 speedometer malfuntion
Old Nov 28, 2016 | 11:00 PM
Oregonite's Avatar
Default '94 940 speedometer malfuntion
The speedometer and odometer in my '94 940 only works when I start driving after it sits overnight then quits after about the first 1/4 mile of driving. Do you think it is the sensor on the rear-end? The ABS light does not come on. I checked the wiring that come out of the sensor and the wires are not broken. The problem started after I had rear brakes and new rotors and calipers put on it, the installer hit the old rotors with a hammer straight on the end of the axles with a 3-5 lb. hammer to loosen the rotors. Would that damage the sensor on the rear-end by any chance? Or it might be a coincidence. Is there a chance of corrosion at the connections of the harness? What is the easiest way to troubleshoot the sensor?
Old Nov 29, 2016 | 03:27 AM
the sensor is pretty darn rugged, its just a little coil of wire and a magnet, it picks up magnetic pulses from a 'tone ring' in the differential, I doubt the hammer blows did anything.
the wire from the sensor is a 'twisted pair' (two wires twisted around each other to keep noise out). this goes through a seal box in the trunk area, then forward along the drivers side of the door sills to a bulkhead connector, and directly to two pins on the back of the speedometer. these wires are brown or brown-white, and green-white, where the brown-white one is grounded at the speedometer. when the right rear wheel is spun, there should be a small A/C voltage on these wires.
Old Nov 29, 2016 | 08:24 AM
lev's Avatar
lev
99% of the time it's the speedo itself, the capacitors fail in all kinds of strange ways causing weird symptoms...
ctphil
Jun 1, 2022 12:05 PM
Oregonite
Nov 28, 2016 10:46 PM
NCVOLVO940
Jan 7, 2011 05:23 PM
janeofdrama
May 24, 2010 08:02 PM
doudah
May 24, 2009 07:53 PM
