940 Engine sensor/switch
Old Feb 17, 2019 | 09:51 PM
SvedishMeatball's Avatar
Question 940 Engine sensor/switch
Hello,
Can anybody tell me what the whitish switch/sensor in the following link does?
http://www.kudria.com/projects/vehic...0turbo_187.jpg
I have a 1993 940 and I just discovered that nothing is pluged into this switch/sensor on my engine, and I can't find any loose wires in the engine compartment.
Thank you,
Kevin
Old Feb 17, 2019 | 10:18 PM
lev's Avatar
lev
The bottom hole is normally capped off. The upper left is a drain petcock.
Old Feb 18, 2019 | 02:28 PM
Thank you !!!
Old Feb 18, 2019 | 07:35 PM
the drain petcock is for draining the coolant from the engine block, after you drain the radiator via its lower hose fitting.
Old Feb 19, 2019 | 06:49 PM
Thank You !!!
I noticed it when I was replacing the header pipe, from the bottom of the car, and I thought that it was a sensor or switch.
jelarf
Nov 30, 2012 10:23 AM
hbmicks
Apr 15, 2011 10:19 PM
aytchgee
Dec 18, 2009 11:23 AM
spackelman
Dec 30, 2008 06:58 PM
baggedb2200
Jun 26, 2008 08:41 PM
