940 seat tracks
Old Feb 29, 2016 | 07:05 PM
Moetheshmoe's Avatar
Default 940 seat tracks
Does anyone know how to separate the top and bottom pieces of a seat track? My ball bearings are so dry they rattle. I removed the pin and the rubber bump stops from the back end but trying to slide them apart towards the front or the back they hit some kind of stop. I don't think it's the anchor bolt in the middle, it's welded on. Any ideas? Thanks
Old Mar 1, 2016 | 01:18 AM
squirt grease into them with a syringe, run them back and forth and squirt in some more, til they are thoroughly greased, then remove any excess thats oozing out of the rails. I did this when the seats were completely out of the car, but the rails were still attached to the seats. I used green marine waterproof bearing grease, it seems to be holding up well a couple years later.
(sorry, no pictures of the greasing, these are the newer pair of 960 seats I put in my 92 740).
Old Mar 1, 2016 | 06:33 AM
I tried to do that but just couldn't get it in there, especially with marine grease(doesn't flow as well). There's a couple of stories on turbobricks about bearings falling out when the tracks are separated but I just can't see how they took them apart?
Old Mar 1, 2016 | 10:09 AM
lev's Avatar
lev
When I did this a while ago, I recall some hammering to get the tracks to separate...
Old Mar 1, 2016 | 03:39 PM
I was able to use a syringe to inject the grease, but you also could use a popsicle stick or something to dab the grease on the tracks where the ***** aren't, then move the slides back and forth to spread it out, repeat until satisfied.
Old Mar 1, 2016 | 03:58 PM
This sounded kind of "brutal" at first, but it worked(light tapping). There's internal rubber spacers that create resistance yet can't be removed until the tracks are separated. Thanks for the tip.
Actually got them apart with my favorite tool - my hammer. Thanks
Old Mar 1, 2016 | 04:48 PM
lev's Avatar
lev
I usually just squirt WD40 to the tracks loosened up, works fine.
Old Mar 1, 2016 | 05:02 PM
I used wd40 to wash the old grease and crud out of mine when the seats were out of the car. its little more than kerosene, and certainly not a good lubricant. then I let them dry a couple days, THEN I squirted marine grease into the tracks.
rspi
Sep 7, 2010 08:24 PM
nick61416
Aug 25, 2007 01:31 AM
Volvo Vic
Nov 23, 2006 03:11 AM
c70girl
Oct 18, 2006 01:49 AM
cool_kyle_3000
Jun 9, 2006 07:31 PM
