940 stutter
Old Nov 20, 2015 | 10:21 AM
Moetheshmoe's Avatar
Default 940 stutter
My '93 940 runs great just about all the time but once in a great while I'll be sitting at a stop sign(in gear) and it will have a quick, momentary stutter or shudder, similar to when the A/C is on and the compressor kicks in. It doesn't do it enough to be a problem but it annoys me and I'm curious what might cause it. Any ideas?
Old Nov 20, 2015 | 11:51 AM
CincyDavid's Avatar
My V90 does that occasionally, one little stutter. I assume it's a fuel delivery issue of some sort, I plan to get off my butt and change the fuel filter one of these days and see if that helps. I may be imagining things, but it seems to only do it when I am running lower octane fuel, never with a tank of 93 octane Shell in its belly.
Old Nov 20, 2015 | 01:42 PM
Hmmm....that's a thought. Here's another....I do notice when my engine is warm and running in Park, if I step on the brakes, occasionally, the idle dips and fluctuates for just a second. That's a sign that the brake booster hose or check valve may have a leak. Doesn't do it all the time and never when cold when everything is shrunk and tight. Since I get that shudder while stopped, in gear and depressing the brakes, maybe that vacuum leak is causing the shudder?
Old Nov 20, 2015 | 08:52 PM
lev's Avatar
lev
Definitely nothing to do with the fuel filter or octane!
It could be the fuel pump or the electric fan kicking in, or who knows? Slight glitches like that are hard to diagnose.
Old Nov 21, 2015 | 03:38 PM
Hey Lev, you're right. I paid close attention to it and it shudders when the fan kicks on. 2 questions: 1-does that mean my alternator's not putting out enough? And 2-aren't the engine controls suppose to compensate? Thanks
Old Nov 22, 2015 | 12:05 AM
lev's Avatar
lev
Well, as in all things, to live happily I try to avoid the pursuit of perfection which usually causes misery. Very applicable to old Volvos with many miles. These cars were designed in the '70's and little glitches like that are a par for the course--we can't explain or diagnose, much less fix, every little lurch, bump, noise, occasional quirk, etc. My cars are pretty spot on and I don't like to cut corners but in the end I don't want to drive myself crazy if they choose to hick up now and then. Enjoy the ride, do less.
Old Nov 22, 2015 | 04:17 PM
the fuel pumps run continuously as long as the engine is running, so thats not it.
electric fans, for sure. a/c compressor cycling, definitely.
my 92 740T, which otherwise runs perfectly does that little stutter at idle sometimes. its never stalled, it just stumbles once then recovers and goes back to steady idle. I've hypothesized it could be due to a sticky idle air controller, but its as likely the fan or a/c compressor.
Old Nov 22, 2015 | 11:46 PM
The obvious question is "Why didn't it do it when it was new?" Something has to be "not functioning". While searching for info I found quite a few Jeep and Dodge owners who's cars actually die when there's an electrical surge. The popular guess is poor grounding. What do you think?
Old Nov 23, 2015 | 04:46 PM
92Sedan's Avatar
If it bothers you that much throw in a fresh alternator/battery, or trade the car for a Toyota.
Old Nov 23, 2015 | 05:18 PM
lev's Avatar
lev
I like that!
Old Nov 23, 2015 | 06:23 PM
What! Sell my Volvo and miss your incredible help? Never!
Old Nov 23, 2015 | 06:32 PM
92Sedan's Avatar
I've had to help Toyota-types too! I just tell them to get a Volvo (to get around oil burning, rust, rattles, and other Toyota issues.)
Old Nov 23, 2015 | 08:22 PM
You must be so proud!
Old Nov 24, 2015 | 02:29 PM
92Sedan's Avatar
I am! I think you'd love one though, I never hear about them having electrical "stumbles" or anything annoying.
Old Nov 24, 2015 | 04:39 PM
Annoying? Like...oil burning, rust, rattles. Maybe you should start selling them.
lemans24
Jul 26, 2008 03:02 PM
JIMMY
Oct 13, 2006 11:47 PM
johnoswald
Jan 9, 2006 08:50 PM
rousha
Jul 19, 2005 05:18 PM
amgqmp1
Dec 4, 2003 12:30 PM
