940 Turbo bad turbo?
Old Feb 6, 2014 | 07:01 PM
Frans562's Avatar
Question 940 Turbo bad turbo?
hi guys, my dad owns a 91 940 Turbo and lately he was complaining that his coolant "disappears", the reservoir is always empty and he doesn't know where the coolant goes, he can't find any leaks and the headgasket was replaced a year ago so it really puzzled him. Today he asked me to change the spark plugs and so I did and when I ran the car after I was done I noticed that the turbo was smoking and it seems like the smoke is coming from the bottom of the turbo. Also, the hose from the coolant reservoir to the turbo is new... any ideas what the issue could be? thanks!
Old Feb 6, 2014 | 07:22 PM
guest01's Avatar
No, clue.
Clearly it's going somewhere, your not looking hard enough.
Old Feb 7, 2014 | 09:24 AM
the turbo has coolant connections, those hoses are down under the exhaust manifold, and go to the side of the block near the oil cooler. maybe those hoses are dying, they are often neglected.
Old Feb 10, 2014 | 09:12 PM
Frans562's Avatar
update. I haven't had time to check the hoses below the turbo I'll check tomorrow, also I took this pic half an hour after making this thread coolant is present where the turbo and manifold meets. White smoke comes out of the exhaust occasionally...
Old Feb 10, 2014 | 10:39 PM
I don't know any mechanism coolant can get into the exhaust manifold above the turbo, unless there's a leak somewhere thats spraying it.
here's my greasy 92 turbo.. I've since replaced most of hoses and got most of the leakage under control.
Old Feb 12, 2014 | 12:43 AM
Frans562's Avatar
your turbo looks different than what my dad has in his car
Old Feb 12, 2014 | 12:59 AM
mine is a mitsubishi, earlier 740s used garrets.
also, they changed the air plumbing in 1992.
1992:
1991 (my sons old car)
turbo on the 1991
(dusty engine from too many desert roads, my kid is an adventurer...)
Old Jan 13, 2022 | 03:27 PM
PPG's Avatar
PPG
I know, this is a very old thread, but did you ever find out, what was the problem? I have a 940, B230ft, doing exactly the same! Draining the coolant, sometimes quickly (1/4 liter in a few days/a few km), sometimes slowly (1/4 liter in 1000 km.). Occasionally white smoke from the exhaust. But the same spot of coolant where the turbo and manifold meet, everytime I need to add up with coolant...
Old Jan 13, 2022 | 08:43 PM
Moetheshmoe's Avatar
White smoke means it's burning it, which means it's leaking through the head gasket.
86volvoguy
Apr 20, 2017 10:50 PM
jclark5093
Nov 21, 2010 08:28 AM
flippyflipz
Dec 2, 2008 01:52 PM
02VolvoS40
Feb 4, 2008 06:05 PM
