940 turbo radiator
Old Dec 13, 2013 | 09:45 PM
joeyfv's Avatar
Default 940 turbo radiator
I own a 940 trbo and I can not locate the radiator cap. Does it have one or is it self contained? Joe
Old Dec 14, 2013 | 12:14 AM
lev's Avatar
lev
cap is on the overflow tank.
Old Dec 14, 2013 | 12:01 PM
joeyfv's Avatar
I know about that one but is their one on the radiayor itself
Old Dec 14, 2013 | 12:07 PM
lev's Avatar
lev
no.....
Old Dec 14, 2013 | 09:34 PM
joeyfv's Avatar
That's weird. Reson I ask is last owner only used water and no antifreeze in summer. So how do I drain water and replace with freeze before rdiater cracks frozen
Old Dec 14, 2013 | 11:45 PM
lev's Avatar
lev
drain the radiator through the bottom hose. there may be a plug on the radiator bottom too. then fill with coolant mix through the overflow bottle. burp the hoses to eliminate bubbles.
Old Dec 17, 2013 | 04:25 PM
Tubaman's Avatar
Default 940 Radiator
If your 940 is a turbo there is a spigot kind of thing near the remote oil filter/oil cooler that you can also use to drain all the water out of your engine. It require a 12mm wrench. I'm not familiar with non turbo 940's.
Old Dec 17, 2013 | 04:29 PM
that spigot on the block will take nearly forever to drain the block, and won't totally drain the radiator.
the lower radiator hose is the correct answer
never ever use plain water except in an emergency on a vehicle with alloy heads... you NEED the anti-corrosion agents in quality antifreeze/coolant.
do note, 92+ 7/9's have a different larger radiator than older models, at least I know the turbos do.
Old Dec 19, 2013 | 02:19 AM
lev's Avatar
lev
the "spigot" is to drain/flush the block. all b230s have it. it is not possible to drain the radiator out of there-physics... the cooling system should be flushed to clean the block, heater core, etc. just run some water with flushing agent to operating temp., drain again.
that4wdwagon
Dec 8, 2014 05:23 PM
mikeawd850
Nov 30, 2012 02:26 AM
gabanja05
Jun 15, 2011 12:12 AM
geminiys
Jun 18, 2007 10:22 PM
GaryBrad
Apr 24, 2005 03:48 PM
