95 240 Sedan, back passenger door will not open
Old Feb 23, 2011 | 03:58 PM
KeirinsMomma's Avatar
Default Please delete-moving to correct forum.
Please delete
Hi, very new here. I drive a 95 850 Turbo Sedan, and after replacing just about every part of this night mare of a Volvo, the back passenger door will not open. Not from the inside or outside. The lock pulls up just fine, but the door is just stuck.
Any ideas I can do/check myself to avoid the shop fee?
Our second baby is due any day and I really need both back doors to work!
Thank you very much for any suggestions.
Old Feb 24, 2011 | 11:58 AM
swiftjustice44's Avatar
Is the car definitely a 1995 model or is it a 240Turbo? 240 turbos were last built in 1985. If it is a 95 and a turbo, then it would have to be a 940T. Doors are a bit different.
Old Feb 25, 2011 | 11:11 AM
Sorry, it's an 850, It is a 95 and it is a Turbo. (My last was an 80's 240 Turbo)
Old Dec 4, 2021 | 04:34 PM
dlbordessa's Avatar
Default Back door wont open
Originally Posted by KeirinsMomma
Please delete
my 1990 240 had the same problem. You have to get the inside panel off, which is a pain with the door closed, but possible. Then take out the door latch. There was a small spring in mine that had gotten out of position. I fixed that and the door works. Sometimes after I shut it, it acts like it won’t open again. When I pull up on the lock from the inside it opens fine. Hope this helps
Forgot to mention.. to get door open to get to latch, use long flat screwdriver and a flashlight to push up tab inside door latch that will open door.
rcvolvo
Apr 10, 2016 01:26 PM
86volvoguy
Jun 11, 2012 12:43 AM
Carey
Jun 26, 2011 06:06 AM
jilcomes
Jan 27, 2011 05:42 PM
Shaun Oriold1
Oct 17, 2010 06:01 PM
