240 rear door jammed shut
Old Jun 6, 2012 | 03:37 PM
86volvoguy's Avatar
Default 240 rear door jammed shut
The rear door on the driver's side of my '86 240 wagon was sticking, but I could get it open. Then I got angry one day and slammed it. Bad move! Now I can't get it open. The inside door handle feels like it is working. Does anyone have any suggestions? Would it help to loosen the door hinges and try to wiggle the door back and forth? Help!
Old Jun 6, 2012 | 07:50 PM
Titan Joe's Avatar
Check this out at post #7:
https://volvoforums.com/forum/volvo-...1-244-a-61233/
As it said, you can try pushing in to get it to release and then adjust the latch.
Old Jun 6, 2012 | 09:04 PM
86volvoguy's Avatar
Thanks, Titan, I'll give it a try!
Old Jun 9, 2012 | 09:00 PM
86volvoguy's Avatar
Titan Joe, you are a miracle worker! I tried pushing the door in with my hip, lifted up the handle, and the door popped right open! A thousand thanks.
Old Jun 9, 2012 | 09:12 PM
lev's Avatar
lev
The doors get STUCK due to non use. Open them up now and then, may be even lube the hinges and the door strikers.
Old Jun 9, 2012 | 11:22 PM
piv15's Avatar
The doors on my Volvo wagon were beginning to get awful at opening and closing. They'd stick. some WD40 solved that issue!
Old Jun 10, 2012 | 12:27 AM
wd40 is a cleaner, and rust preventive, its not a good lubricant. its not a good penetrant either.
use some white lithium grease spray on the locks, applied where it needs to go, and wipe off where you don't want it, like the paint and the outside of the striker plates.. I put this on the back seat latches in my wagon, too, it stops them from squeaking and rattling on bumps and rough roads.
Old Jun 10, 2012 | 06:48 PM
86volvoguy's Avatar
Good advice, lev. Let me add the following: Don't lose your temper and slam the door shut as hard as you can.
Old Jun 11, 2012 | 12:43 AM
91-740Turbo's Avatar
Yeah, my dad had to tell that to a lot of people when they came into the gun store with their guns filled and dripping with WD-40 and saying that it will not work anymore.
WeeShell
Aug 29, 2014 04:36 AM
adonis
Jan 22, 2012 09:16 PM
meritage2
Aug 24, 2011 09:52 PM
Dennis Tobin
Jun 18, 2011 03:11 AM
850forum
Nov 28, 2005 09:41 PM
