ABS Front wheel speed sensor
Old Apr 24, 2011 | 05:49 PM
j2carl's Avatar
Default ABS Front wheel speed sensor
I need to replace the ABS front speed sensor on my 1991 240. I inadvertently damaged it in the process of removing the strut assembly. The aftermarket part price ranges from $250 to $300. So, looking for a cheaper alternative, I noticed it looks the same as the 740 sensor except for the wire harness connector. The 740 sensor is also about $100 cheaper.
Can someone tell me if the 740 sensor can be used if I cut wire connector and splice in the 240 connector?
Thanks.
Old Apr 24, 2011 | 10:40 PM
lev's Avatar
lev
You can get that part used for nothing. Barring that, the 740 should be just fine...
Blkwidow
Sep 21, 2013 02:34 AM
MaxBoost13brx
Jun 8, 2008 09:42 PM
MaxBoost13brx
May 30, 2008 11:31 PM
waterkr1
Aug 30, 2007 05:44 PM
shamusom
Jul 11, 2006 09:40 PM
