AC cycling during driving...92 240 GL
Old Sep 14, 2005 | 05:59 PM
scottbr997's Avatar
Default AC cycling during driving...92 240 GL
Driving at speed my AC compressor/clutch cycles on and off every 20 - 30 seconds. The sound is audible and sounds like a drag being put on the engine. The AC works great.
Is this normal or could it be a relay issue?
I have a 92 240 GL. Thanks.
Brad
Old Sep 14, 2005 | 07:55 PM
matthewensey's Avatar
Default RE: AC cycling during driving...92 240 GL
It sounds to me like you may have a low refrigerant charge. If you had some guages to get some pressures for me on the high and low side, I could help more. It could also be a compressor cycling pressure switch located on the accumulator. I've heard of people "jumping" the switch with your problem, and it fixed it.
Old Sep 14, 2005 | 08:57 PM
The compressor will cycle some if you have the fan on low fan speed to prevent it from freezing up.
But every 20 to 30 seconds sounds like you are low on freon.
sghokie
Jul 25, 2011 05:00 AM
flyboy
Sep 10, 2008 10:11 PM
tngreg
Jun 21, 2008 03:26 AM
Nand12
Jun 1, 2006 09:08 PM
frails
May 3, 2006 09:33 PM
