AC System Removal
Old Oct 10, 2005 | 05:51 PM
vovo racer's Avatar
Default AC System Removal
Ive been removing components of my a/c system. Ive take the compressor out, the accumalator out and the hose between the two out. Since i've taken those out my car now makes a tinny rattling sound on start up and idle. It still runs fine though(I can hit 110mph easy). Any clues as to what is up?
Old Oct 10, 2005 | 05:54 PM
Default RE: AC System Removal
Check the heat sheild for the exhaust.
And look for anything else that could possibely be loose.
Old Oct 10, 2005 | 06:02 PM
vovo racer's Avatar
Im dumb. sorry. where and what is the heat shield?
Old Oct 10, 2005 | 07:07 PM
Carbuff's Avatar
ORIGINAL: vovo racer
Hi Mr Racer,
The Heat Shield is a two-piece plate surrounding the exhaust manifold on the B230 engines. It ducts warm air to the air box through a silver/serrated hose that runs along the front of the engine bay.
If you remove the (12 or 13? I forget) mm bolts you will see that the heat and vibration will have cracked the metal. Then the vibration of the engine will allow a resonance.
I have found that the silver metal hose can also rattle in it's clips.
If you are actually racing the car, you don't need the ducting and hose!
Cheers
Old Oct 10, 2005 | 08:15 PM
There is also another one on the downpipe.The pipe after the manifold.
robingichuhi
Feb 22, 2017 04:34 PM
rolling2
Oct 20, 2010 01:08 AM
abc05
Feb 2, 2010 05:10 AM
dannydoo
Oct 16, 2006 08:52 PM
