Air conditioning problem
Old May 24, 2010 | 03:35 PM
greylady's Avatar
Default Air conditioning problem
OK. I have a 1990 Volvo 740 wagon and a question. My air conditioner is busted and the first mechanic theorized the freon was leaking from the compressor. So we got another one. But then we read somewhere that we'd need an accumulator. The mechanic confirmed this, so we got a used one and called yet another mechanic (problem diagnosed just before road-trip vacation) to put it in. Second guy told us we'd need a new accumulator because a used one allows moisture in, which is apparently not good. So two questions, really: Does anyone know if we need an accumulator for this repair? And do we need to get a new accumulator? Any help = greatly appreciated.
Old May 24, 2010 | 07:29 PM
swiftjustice44's Avatar
Short answer...Yes. The accumulator (also known as a drier) contains a bag of dessicant that removes trace moisture from the system. Odds are high any 20 year old used one you find is worthless. Once the system leaks down to atmospheric pressure moisture and any other contaminants find their way into the system.
By the way, rather than playing a guessing game, any genuine tech would add dye to the system before adding refrigerant so any future leak(s) can be traced.
Old May 30, 2010 | 01:37 AM
Joseph/TX's Avatar
I absolutely agree. The dessicant in the accumulator is kind of like a sponge, except that once it's soaked, it doesn't dry out. As a general rule, you replace the accumulator ( or the receiver-dryer on an expansion valve system ) any time you open the system, which of course you would have to do to replace the compressor. An accumulator from a wreck yard wills undoubtedly be saturated from being open to the atmosphere and will be about as useful as a blown fuse. If you buy a new one, you'll notice that the openings are all plugged and should remain so until it is actually installed.
roybis
Jul 22, 2020 07:47 PM
king1199
May 4, 2012 11:05 AM
Prospect62
May 27, 2010 07:47 PM
faulkejb
Jun 3, 2007 05:15 PM
