annoying constant beeping
Old May 13, 2015 | 03:11 PM
bigarms23's Avatar
Default annoying constant beeping
I have a 88 240dl and as of 2 days ago every time I put the key in the ignition the beep come on and stays on with seatbelts latched door closed the only time it stops is when I pull out the key any fix it suggestions
Old May 13, 2015 | 03:46 PM
check the drivers door switch. its grounded via the screw that holds it into the door frame, and switches to ground when the door is opened.. it should only 'bing-bing' when the key is in the lock AND the drivers door is open, so if that wire is shorted to ground somehow, its going to bing all the time, I bet.
right now I can't actually FIND this circuit in the wiring diagrams for a 87/99 240 :-/
Zebulon
Dec 22, 2015 09:45 AM
bam210135
Sep 16, 2011 08:28 PM
C70CoupeMaui
Nov 26, 2009 02:46 PM
simonh9
Oct 9, 2005 02:17 PM
momzR
Jun 20, 2005 04:04 PM
