anyone just remove all there a/c components from the engine
Old Aug 27, 2011 | 09:10 PM
guest01's Avatar
Default anyone just remove all there a/c components from the engine
my a/c doesn't work, as doesn't pretty much all older volvo's I've been in. it's not consistenly hot where I live and seeing how there's not even an a/c machine in the shop I work in
long story short I'll more then likely never get it working, though it would be cool if it was. curious if other have pulled everything out. don't really expect to gain any measurable hp or mpg. it sure would free up some space in the engine bay though.
Old Aug 28, 2011 | 07:37 AM
jagtoes's Avatar
Through the years I have rebuilt my AC system on our 89 740. It's not a big deal and the major cost was the compressor and condenser. I have replaced every component except the evaporator and have done the usual 134A conversion. We have the normal 4 seasons here where summer months run 80-100* temps. The car runs at 40* from the center ducts and has been no problem for years. It's an easy system to fix and keep running.
Old Aug 29, 2011 | 09:40 AM
guest01's Avatar
it would be cool to get it working. I can't say that I really now what I'm doing when it comes to a retrofit. I've yet to actually retrofit a system. plus I'm using to using professional shop grade recovering machines.
Do you have any links to info on the bare minimum on recharging or going about finding the leak and retrofiting an old system out of use for awhile??
Old Aug 29, 2011 | 05:26 PM
brickrunner's Avatar
I wouldn't remove the A/C components, you never know if you are going to want to fix the A/C in the future. It might also affect the desirability if you were to sell the car in the future.
Old Aug 29, 2011 | 08:19 PM
Koriflame's Avatar
Mine has everything to do with the A/C removed. I bought it like that, I really don't need AC though.
Old Aug 29, 2011 | 08:45 PM
guest01's Avatar
this is true. I'll probably just leave it alone and look into what it would cost to fix.
Old Aug 29, 2011 | 08:59 PM
My A/C broke about a year ago and I didn't even bother to check what was wrong with it because I thought it was something major and my trusted mechanic had recently retired. I am now looking into it and it is starting to look like it is a $30 part. I should have checked it back then.
Old Aug 30, 2011 | 01:59 PM
brianb's Avatar
I totally agree. Mine was completely removed by the previous owner and I sometimes wish he would have left it alone so I could have tried to fix it. It gets driven the most when I put my Mustang away for the winter but, I do use it in the summer when I take my dog anywhere so, the AC would be nice to have then.
Old Aug 30, 2011 | 11:18 PM
when I replaced the radiator on our 87 240, I removed the condensor, and about half the plumbing as the AC hasn't worked in 15+ years.
we also have a non-functional compressor, acting purely as an idler pulley for the power steering pump (the original compressor had a frozen clutch and burned the belt). IPD has a idler pulley kit that works for some years, but not 87 at least. (if anyone knows of a way to re-rig this so the PS can be driven without the AC compressor, I'd love to get rid of that bogus compressor)
I haven't bothered to remove the dryer/reciever, or the expander under the dash but if I ever have to do a heater core, I might.
donf
Oct 25, 2010 10:38 PM
I8ASaleen
Sep 20, 2010 09:21 PM
lupodellalfa
Sep 20, 2009 10:11 AM
dpilot
Jan 26, 2009 02:29 AM
chef
Aug 17, 2008 01:16 PM
